Author Topic: Are basses wired the same way as guitars?  (Read 814 times)
morglan
« on: March 16, 2016, 02:32:41 PM »
Hi all,
I've always rewired my guitars, and now my brother wants me to rewire a couple of his basses.
They are both Epiphones (a Thunderbird and a Les Paul Special bass).  He wants me to convert them to master volume and tone, with the third pot unused.
My question is, can I simply follow a guitar wiring diagram for this set-up?
Should I replace the stock pots (and will it make a difference if I do?)
He doesn't want a blend pot installed, but is it desirable in basses to install a "blow switch" (to bypass the tone control and go straight to the jack)?  All of my experience is with guitars, so I don't even know what bass mods would be desirable...
Re: Are basses wired the same way as guitars?
« Reply #1 on: March 16, 2016, 03:38:31 PM »
He wants both pups all the time, no choices?  Yeah that should work exactly like a guitar.
morglan
« Reply #2 on: March 16, 2016, 04:07:49 PM »
Just spoke with him, and I'm going to install a 3 way switch in place if the unused pot, and replace the other 2 pots with better quality 500k parts.
clankenstein
  • Never Gutless!
« Reply #3 on: March 16, 2016, 07:06:18 PM »
Sounds good.is he happy with the pickups?
Louder bass!.
« Reply #4 on: March 17, 2016, 03:37:48 PM »
Sounds basically like a Telecaster. I'm currently re-wiring a Frankenstein P bass with a neck humbucker and a 3-way switch. The switch itself is of a Gibson style, so as long as you can decode each component then there is no difference between bass and guitar wiring.
